Stand alone clutch reservoir
35
18
Drag Strip
Northern Michigan
I'm in the middle of my v6 to Coyote swap with also an auto to manual swap at the same time.
Just looked at my donor pedal assembly for the first time. I'm beginning to understand what it is I'm working with! 🤔
I do however have an automatic brake master cylinder with the automatic reservoir, minus the nipple I need to feed my clutch master cylinder. Does anyone make a simple stand alone clutch master cylinder cup that can be used for my swap? I'm envisioning a small aluminum cup with a nipple and a cap that seals with an o-ring.
Anybody have an ideas or suggestions?
Thank you.
I had one that I bought somewhere as a kit, maybe it was from a newer GTO or something. It constantly splashed/leaked out of the cap and then was almost empty.
Switched it out for a small tilton remote reservoir and no leaks, works great. I had them laying around, but if you had to buy, it is the top part and bottom one from this screenshot. (and maybe a cap if it doesn't come with the top one)
DaveW
I would imagine the one from the ranger with the bottom facing nipple would work too. I'll have to build a bracket anyway, I'm just trying to prevent extending the original hose if possible. The hose looks to be a reinforced braided hydraulic line of some sort.
The hose from reservoir to master doesn't need to be rated for pressure. Its just a feed line. It just needs to be compatible with the fluid.
