S197 Diff fluid
I can smell it just from your description🤣
I hit with meatball flag after meatball flag until I finally said Listen it’s just going to smoke. It’s not broken and it’s not leaking. It’s just gonna do that and then control said “I mean okay as long as it’s not gonna break”
I do not remember where the cut off was the calipers fitting or needed an adjustment. My stock 2011 calipers cleared. When I needed replacements the right side was out of stock everywhere. My local Ford dealer managed to find one from 2008 or 2009 sitting on a shelf at a dealer in Hawaii. It rubbed a little before a few strokes of a file. It did not take much and I am still running the same caliper.
Like @67GTA said some kind of expansion will help. I am running a JLT expansion tank. Unfortunately they are discontinued. Everything else out the is pricey. I just found this looking around - DR3Z-4022-A "KIT HOSE ASY" . Might be a cheap fix to get you though. I think it was the original TSB for the leaking vents. It's a hose extension that has the vent sitting higher than having it connected straight to the axle. It also gives you a tad of expansion. Just me - I wonder if you could keep going with more hose , like another foot up along the frame attached with zip ties for more volume. The only other thing I would do is use some high temp gasket maker to the fitting and some around the fitting once it's tightened. My JLT fitting ended up leaking. Permatex motoseal fixed the issue. I used that stuff on modified chainsaws with 180-200 psi compression as the alone cylinder gasket. View attachment 97992
The extra hose is going to be my first attempt after putting the correct fluid in
Sorry I'm a little late to this thread. So, getting ready to change the diff fluid for the first time (+ about 2500 miles, including maybe one hour track time) since installing 4:10 gears and Ford performance (non-Torsen) LSD. If I buy a gallon of the Redline 75w140 do I need anything else? Amazon says friction modifier is included in the gear oil. Thanks as always.
Redline sells 75-140 with and without friction modifier. The lube with modifier was fine in my Ford trac loc without additional modifier.
Silly question, but what how does a failed axle seal evidence itself?
I autox'd my boss over the weekend. My partner and I both codrove for a total of 16 runs (8 runs each, half in the morning, half in the afternoon). In the mid afternoon I noticed what smelled like gear oil while adjusting rear time pressures, and by the end of the day I saw lots of drops of fluid on the inside of *both* rear wheel barrels.
Differential lube will "normally" overflow from the vent on the top of the axle tube, to the left of differential. The only way differential lube can find it's way to the inside of your wheel barrels is through the axle seals. Are you sure you're seeing diff lube and not brake fluid?
If it is diff lube the distinctive smell is unavoidable, and it leaked past the seals. Make sure your vent is not obstructed, heat will build pressure that could force diff lube past the seals. That it happened on both sides at the same time makes me suspect this. Otherwise, time for new seals.
I'm not 100% confident its diff lube. I guess it would have been brake fluid, but the odor suggests otherwise. It was quite pungent, different from brake fluid.
The car has 127 miles, so I would not be surprised if the vent is clogged or otherwise obstructed/needs to be replaced. I haven't inspected it yet.
127 or 127k? 127k could be normal wear on the seals. A Boss with only 127 miles probably means it was sitting stationary for quite some time, and the seals can dry out and stiffen, shrink, or crack if they aren't in contact with oil occasionally.
My Boss had a bad axle seal from the factory - first autocross, I had a thin layer of gear oil on inside of the passenger-side wheel. Fixed under warranty and it's been fine since. But the longest it sits is probably 3-4 months over the winter.
Sorry for the typo, 127 *thousand* miles. Lol I wish it only had 127 miles on it.
It appears no one around me really wants to do axle or diff work. One local dealer initially quoted me $1k for parts and labor for both rear axle bearings and seals, then called me back after I dropped off the car and said they misquoted me; the actual quote is now $1600. I told them to not touch the car and I picked it up shortly there after.
So I called a few other places, and most shops don't want to do that kind of work, so now I'm considering doing it in my driveway. I'm a little intimidated if I'm honest.
I'm also considering just putting it off - replacing the vent tube and seeing if it continues to bleed fluid.
Somewhat related - I just purchased a 2026 dark horse with handling pack, so now my motivation for working on the boss is at an all time low at the moment.
... One local dealer initially quoted me $1k for parts and labor for both rear axle bearings and seals, then called me back after I dropped off the car and said they misquoted me; the actual quote is now $1600. I told them to not touch the car and I picked it up shortly there after.
Replacing the vent and monitoring the condition is a nothing-to-loose first step. AT 127K miles it may need seals soon anyhow.
Replacement parts and consumables, fluid, ect. should be ~$200 and a shop should be able to complete the replacement in around 3hrs. So...
$1000 job seems a bit high to me, maybe if it's your only option you might absorb it. $1600? Absolutely hell no!!!
DIY is a very attractive option and the intimidation stems from unfamiliarity, It's not a high-level, technical skills requiring job. Just a few special tools and basic mechanical ability will get you there!
This guy breaks it down very well:
Oh yeah, thanks for the link. I've watched that video several times already. He does a great job.
And looking at different sources for parts ... seals + bearings can be had for under $60 before shipping, and 3 quarts of fluid for $120. So yeah, $200 (plus whatever for tool rental). I'm just ... scared, I guess, of opening the diff and something happening. In that video, dude said he lost several hours when spider gears fell in on themselves. I'm not prepared for something like that.
The last two times I've worked on this car, I've caused some other secondary bad behavior, and I'm a little gunshy. But I'll get over it; it seems totally doable as a driveway job.
Your Boss will have a Torsen differential so no spider gears/sprung steel tabs to worry about.
Lol I appreciate that. Shows that I don't know what I'm talking about.
We’re all learning here as you’ll see with the clarity that Dave_W provided. That’s the great thing about this site - ton of knowledge here without the typical forum bravado. This is absolutely a job you can tackle and you have a great group here that will help you through it.
Not necessarily. The Torsen only came on the Laguna Seca, or if you got the Recaro & Torsen option on the non-Laguna Seca. If it's a non-LS without Recaros, it will have the clutch-type diff.
