Thank youLater
Thank youLater
I hit with meatball flag after meatball flag until I finally said Listen it’s just going to smoke. It’s not broken and it’s not leaking. It’s just gonna do that and then control said “I mean okay as long as it’s not gonna break”I can smell it just from your description
I do not remember where the cut off was the calipers fitting or needed an adjustment. My stock 2011 calipers cleared. When I needed replacements the right side was out of stock everywhere. My local Ford dealer managed to find one from 2008 or 2009 sitting on a shelf at a dealer in Hawaii. It rubbed a little before a few strokes of a file. It did not take much and I am still running the same caliper.Thank you
The extra hose is going to be my first attempt after putting the correct fluid inLike @67GTA said some kind of expansion will help. I am running a JLT expansion tank. Unfortunately they are discontinued. Everything else out the is pricey. I just found this looking around - DR3Z-4022-A "KIT HOSE ASY" . Might be a cheap fix to get you though. I think it was the original TSB for the leaking vents. It's a hose extension that has the vent sitting higher than having it connected straight to the axle. It also gives you a tad of expansion. Just me - I wonder if you could keep going with more hose , like another foot up along the frame attached with zip ties for more volume. The only other thing I would do is use some high temp gasket maker to the fitting and some around the fitting once it's tightened. My JLT fitting ended up leaking. Permatex motoseal fixed the issue. I used that stuff on modified chainsaws with 180-200 psi compression as the alone cylinder gasket. View attachment 97992
That's what I ordered. Thanks for the reply.Redline sells 75-140 with and without friction modifier. The lube with modifier was fine in my Ford trac loc without additional modifier.
Replacing the vent and monitoring the condition is a nothing-to-loose first step. AT 127K miles it may need seals soon anyhow.... One local dealer initially quoted me $1k for parts and labor for both rear axle bearings and seals, then called me back after I dropped off the car and said they misquoted me; the actual quote is now $1600. I told them to not touch the car and I picked it up shortly there after.
So I called a few other places, and most shops don't want to do that kind of work, so now I'm considering doing it in my driveway. I'm a little intimidated if I'm honest.
I'm also considering just putting it off - replacing the vent tube and seeing if it continues to bleed fluid.
In that video, dude said he lost several hours when spider gears fell in on themselves. I'm not prepared for something like that.
Not necessarily. The Torsen only came on the Laguna Seca, or if you got the Recaro & Torsen option on the non-Laguna Seca. If it's a non-LS without Recaros, it will have the clutch-type diff.Your Boss will have a Torsen differential
Lol I appreciate that. Shows that I don't know what I'm talking about.
