I'm placing this in the Boss section because there's lots of good info for the coyote based engines and I want everyone to see this.
Oil separator
Is should be available in December and retails for $189. Specifics are:
1. A lot of development went into the filtering media, "it works great".
2. It's made out of glass filled nylon 6 for durability.
3. Uses a throttle body gasket vs an O ring found on other separators.
4. The hoses come from the same supplier that makes the OEM hoses.
5. It uses OEM quick connects with proper seals.
Ford was going for the OEM look and quality for durability. "We did it right" There should be specific fitments for the coyote and voodoo engines.
Voodoo Crate Engine
They currently do not plan to offer the Voodoo engine from the production car as a crate option. It is exclusive to the car. However, parts will be available. Heads, intakes, blocks should be available 1st quarter 2016.
GT350R Wing and Splitter
This is still being discussed. The wing is expensive and they are not convinced that the business case makes sense. No specific comment on the splitter but I imagine it will be available at some point especially if its on the GT350R-S.
GT350R Rear Seat Delete
Both the RSD and seat kit for the R are available now.
http://fordperformanceracingparts.com/parts/part_details.asp?PartKeyField=25876
GT350 lowering springs
They are in development.
GT350 MRC track oriented damper programming update
They are looking into this.
GT350 TracKey
It's in development and will have some new features. This is still a ways out so be patient. The software is completely different from the previous TracKey software program.
GT350 Owners Kit
This is a possibility but no specifics were given.
GT350 Track Attack
This was discussed at the Track Tour events but no official information is available at this time.
**When this does get announced I'll see if we can get a specific class for TMO members.
Voodoo Intake for Coyote Engines
They are working on a complete kit that will include a calibration that is CARB approved!
Voodoo Valve Springs for a Coyote
The heads look similar but are different. They recommend swapping the heads and valvetrain. Cams will also be offered that work with the coyote firing order. 8)
Hood Struts
"Ford Performance will be selling a hood strut kit. Very clean OEM look with the Ford Performance logo on them. They were on their car at SEMA. Should be out by year end...."
Oil separator
Voodoo Crate Engine
GT350 TracKey
GT350 Owners Kit
GT350 Track Attack
Hood Struts
