Adjustable End Links
6
Florida
2020 GT PP1, 13k miles. Tracking mostly. I recently added adjustable BMR camber plates and Steeda adjustable end links. I have the stock sway bar and SR Performance lowering springs. Stock shocks. I have a faint clunking sound when going over bumps. Any ideas? I have not adjusted the end links yet. Could they be causing the problem? I also did not modify the bump stop. Thanks for the help. I’m 16 hours into finding the clunk. LOL.
484
451
MD
Steeda endlinks have a grease fitting. Sometimes they come in contact with the strut when turning or going over bumps. It happened to me and put a small dent in the struts. I swapped out for links without a grease fitting. I would check to see if there is contact between the fitting and the strut body when it’s on the ground
6
Florida
Right on. Yes, mine have grease fittings. I’ll check that as well. Thank you.
Two others that I've experienced: The upper spring perch / bearing (forget exact name) could be bad. Or, the one I chased for 1 entire year: The strut itself was bad, finally could see the shock's shaft moving while applying force to the tire.
6
Florida
I will check that as well. Thanks!
