Aluminator maintenance schedule for my track car ?
Canmore
Hey all.
I put a 5.2XS Aluminator into my 13 BOSS 302s track car late last year and I'm looking for some general direction on a maintenance schedule for changing fluids. Ford didn't include anything with the engine and I can't find anything on
FordPerformance.ca
I'm currently only attending track days but plan to move into time attacks and beyond in the near future. I just gotta get comfortable with all the extra HP the Aluminator brings vs the old 302 I pulled out of the car.
How often to you all change oil in your cars. How often to you change other fluids? Any input would be appreciated.
QSS
5,320
4,332
Typically its after every 4 hours of track use. You can see that on page 16 of the 302S owners manual (just enter BOSS 302S OWNERS MANUAL in google). But it depends on your driving style and how aggressive you are etc. Since you have a 5.2XS, if you take it over 8000 rpm all the time maybe you might want to cut down the oil change interval a bit. More HP, more heat, more wear!!
My events were usually only 1 hour of track time so I would change oil every two or three events. Some people change after every event, but that can get really tedious when a oil change requires over 14 Liters of oil.
208
318
75024
On my GT500 the supplement says 'One track weekend or approximately 4 hours of track use' for oil changes, so similar to the 302S. Seems like a good standard for a heavily worked 5.2.
6
7
Alberta
4 hours of track time seems reasonable for an oil change. The Boss 302s manual also says diff oil and tranny fluid every 4 hours as well and brake fluid should be changed after each event. Are all of you changing your fluids this often?
I wonder if what the recommendations would be for the 5.2 aluminator.
QSS
5,320
4,332
QSS
For brake fluid it depends on what fluid you are using. For mere mortal stuff, every race. For Castrol SRF, a much much longer interval.
153
167
Arizona
QSS
My track events are ~80 minutes per day.
I change engine oil every 2 events, sometimes 3 if its cold weather, always do oil analysis and the oil is always fine. I bet I could stretch this but no reason to.
I use Redline MTL in my MT82 and I've noticed it will get harder to shift after 3-4 events so I change the trans and diff on that schedule. I do not have coolers which I think would help immensely.
I run Castrol SRF and have never had a single issue with the fluid. I bleed them every few events and refill as required. I've flushed it once but it seemed like a waste of time.
