Boss Track Attack Brake Caliphers
Want the same brakes that you used at the "Boss Track Attack"?
Here's what I've got..... I'm going in a different direction.
Service replacement for the Mustang FR500C and FR500S race car (will fit all S197 Mustangs with proper wheel)
Brembo, F40/F50 style radial mount with 40/44 pistons
Includes a pair of front calipers / hardware to attach calipers to mounting bracket and mounting brackets (the kits on ebay don't include the Caliper Bracket)
FR500S FRONT BREMBO BRAKE CALIPERS - M-2320-D (quick change pins - no pounding out pins to change pads)
FORD RACING MUSTANG FR500C CALIPER BRACKET - M-2134-R (This is the part that's hard to find and makes this all work together)
$850.00 + shipping to your door
Pads are not included; Use a FMSI D810, D968 pad or the Ford Racing M-2001-R (About $300.00)
Hoses not included; Use hoses from a GT500/Track Pak/Boss 302 (you can reuse your stock hoses)
Hats/Rotors not included; Use the Girodisc 2pc floating front rotors for Ford FR500S ($1000.00 for a pair)
(http://www.girodisc.com/FR500S_c_979.html)
So for $2,150.00 you can have the same brake package as the Boss 302 "Track Attack" cars.
Parts are located in Valrico, FL
Doug
OH? When I attended the rears were the same as the stock Boss 302's.
Got any pics? I like to see what they went with.
If you try and buy this as a kit from other vendors you're looking at $3,000 for the fronts. So $2,150 isn't so bad.
I am pretty sure they used the PFC cross drilled, two piece rotors. All the other pieces are stock. Great price for the front setup though. GLWS.
