- Thread starter
- #261
Re: Boss Transmission Issues Poll Discussion Thread
Remember there are two issues owners are having: clutch pedal sticking to the floor and shifting lock out. So the good news is I didn't miss a shift yesterday in five sessions. I had hoped both would be fixed by replacing the clutch but it appears only one issue was resolved. I'm not calling it a fix yet until I drive Sonoma and Laguna Seca which I'll do in the next month. You use second gear at both of those tracks and I had lock out almost every time shifting from 2->3. Stay tuned.
BTW the clutch engagement is getting better but still far from ideal for me. I suspect the engagement will continue to improve.
The problem with all of this is there are no definitive answers on the clutch sticking (although the spring and design look to be). I'm really curious if the GT500 is actually different. The clutch feel after removing the spring wasn't as bad as I feared but I still like the stock feel better. If the GT500 isn't really different then maybe an aftermarket clutch helper spring is in order. I'll do some research on that.Justin said:is your mcleod sticking to the floor? if so that is very crappy man. if the assist spring removal stopped that then I would look heavily into getting the GT500 pedal assembly
