- 151
- 0
After 6 track days and 11,000 miles with no issues, I replaced the front brake pads (4 mm left at time of replacement). The front rotors had a slight lip, so I had them turned. The installer assured me the rotors were still at or above minimum spec after turning. The rotors had displayed no issues with vibration at any time. New stock pads installed, I bedded in the rotors/pads per the instructions in the Boss 302 supplement provided with the car, just as I had with the original equipment when the car was new.
After Sunday's track day (4 sessions at Road Atlanta totaling 1 hour, 45 minutes) I now have a slight vibration in the brakes. By the fourth session I could feel the vibration under hard braking, and two days later it is lessened but still there. This is the longest track day I have driven, and I was harder on the brakes than at previous track days. My questions are as follows:
-Is it acceptable to turn the stock Boss rotors, or are they one set of pads and out?
-What is the original and minimum spec for front rotor thickness?
-What impact would this vibration have on braking effectiveness at future events?
-How quickly will the vibration worsen once it has begun?
-Short of turning the rotors again or replacing them, is there any way to reduce or eliminate
the vibration?
I am trying to determine if the rotors were improperly turned, or if I just overcooked them.
the vibration?
