- 18
- 0
Has anybody else have one of there shock adjustment screws break on ether shock? If so is there a direct replacement screw or is a whole new shock required?
onebad58 said:Has anybody else have one of there shock adjustment srews break on ether shock? If so is there a direct replacement screw or is a whole new shock required?
. Where did you get that information? I could not find who makes the shocks and where to get them.65sohc said:The slot on one of my rear adjusters is starting to strip so I wondered the same thing. I've spent the last hour searching and apparently this is common on the Illuminas. Apparently the adjusters come right off and if you contact Tokico they'll send you new ones for free.
They are Tokico Illuminas valved to Ford specs and there have been several reported issues with the adjusting knobs. They can be fixed under warranty so have your dealer check it out before you do anything on your own.onebad58 said:Where did you get that information? I could not find who makes the shocks and where to get them.
