- 152
- 379
1. If you want to run T2, go with a 5.0L.
2. T3 has different rules and allowances than T4. The T4 car has been allowed to upgrade to a lof 11-14 GT parts
3. The modifications or changes aren't just limited to what is on the specline. You've got to read all the Touring (T2-T4) allowances and apply what is allow for all T-Classes. Then more confusion when some rules say T2 only, or T2/T3 only.
3a. Shocks are basically open, and springs are open up to a certain rate(you don't want to go above that rate anyway) Swaybars are limited to the Ford Racing Bars
Cooling is basically open with some limits, ( engine oil, trans, diff, radiator) exahsut open past the stock manifolds. and so on.
4. The spec line parts are parts you can use if you want. So the rear control arms, panhard rod and some bits from Ford Racing are allowed. The shock tower brace is just dead weight.
