Dataloggers?
118
155
MD
AiM: bought direct splice kit because of an ngauge that was using the OBD2 connector. Ended up using the OBD2 connector for AiM and unplugging the ngauge which I couldn't see well because of glare and the info it was providing was unnecessary. The AiM cable is long but can be rolled up and stuffed into the kick panel behind the hood release.
1,809
2,012
5 miles from Mosport
I have the OBD connector but you have to unplug it after your done with it. It won’t shut off.
Yeah, good advice!
If you have a tiny battery like I do the wireless OBD connector will pull the battery down in the 40 minutes between sessions enough that the car won't start.....I try to find a paddock spot pointing downhill in case I forget.......or have lots of friends around. Right @carver?
I'm using a Braille B2015 battery and it's marginal, have to really make sure there are no loads on it during down time.
2,203
1,067
Bay Area
Yeah, good advice!
Thanks, I haven’t had a chance to use it on track yet. I didn’t think just the down time between sessions could screw your day up.
