S550 Does more power = more heat?
A note here. The fuel used was methanol since the Indy Car engines back then were running methanol. Also, we did have a few dyno fires early on since there was a dodgy seal between the 9th butterfly housing and the plenum and the leak fell right on top of the hot side of the turbo. Thankfully there was a bit of oil to give the flames some color...So be extra sure that there are no leaks in your intake system if you choose to try it out. I know, kinda goes without saying
Spontaneous combustion....that was my fear. Cool fuel on hot screws......would she cool or would she blow? LOL.
At Cosworth we called it Pre Compressor Injection where we had four high flow injectors in a ring at the turbo inlet. The PCI system worked very well to cool the incoming charge air as well as to add additional fuel. It was first used on the Cosworth XB in 1992 and it made that incredible engine even more formidable.
Bloody oil pump belt...
This is a really common kit to use on Eco's. https://www.summitracing.com/parts/sno-210
It does a great job of dropping air intake temp and increasing knock resistance. You can also use it to actually fuel the car, but if you're not bang on with the metering, it's very easy to lose the engine.
If you're just using it for intake air cooling, you can probably pick up a good 25 hp or so. There was a technical paper I read from WWII airplanes that tested different mixtures of methanol and distilled water. They found that a 50/50 mix of methanol and water was the best combo for reducing temps. It's also significantly safer.
I was about to reference this same item here, until I read the last sentence.
"They're designed for use in naturally aspirated carbureted gasoline vehicles."
Are they successful on the EcoBoost too?
You bet, it's super common. The CV Fab intake pipes even have a bung in them standard. I have one on my "I got to get this finished" shelf in the garage. If you're anywhere hot and dry, it'll be worth quite a bit of power. If it's not so hot, then the gain won't be as pronounced, but it's still there.
The Eco engine in particular really responds to running cooler. When those engines are run in pro racing (N/A) they run them about 80*C. If you can keep the head temp 190*F, it'll run a lot better. Get a bigger radiator (CSF is an option), box the front of the rad and vent the hood. That still won't be enough if it's hot. I honestly think to do it right you probably have to run a Mach 1 or Shelby nose with an aux radiator on one side and an oil cooler on the other.
Also, get a lower thermostat.
Another option is to just inject water. Also cools the intake temps quite well, and no risk of blowing the engine if the WMI kit has any hiccups. There are various failsafes in various systems, but despite them its not too uncommon for the system/failsafes to break and grenade an engine.
If I were doing it over I'd get an upgraded HPFP and run E85. This will be the most reliable system, and will give some intake air cooling, and lots of additional knock resistance. Eco's are very knock sensitive (headgasket) so that would be my primary focus.
On my N/A Coyote its only worth about 12 hp but I still run it because:
a) the cost
b) it runs so much cooler.
To me its just a no brainer, especially on a boosted car.
Almost 2 years later, but, When you say E85 "runs so much cooler," are you talking about intake temperatures, or does it make a measurable, observable difference in CHT and oil temperature?
Everything runs cooler.
Closest thing to a cheat code in motorsports. My supercharger lid is noticeably cooler when I have my 500 on E- on top of the extra 120HP or so.
I saw similar gains on my super charged 3 valve before I went to the N/A Coyote.
Well....let's throw some real crap into this fan..lol
Wow, you are bringing back some memories. I had forgotten all about that car. I had my doubts at the time, and I still do. It seems that had the technology provided the benefits promised, somebody would have picked it up and run with it by now.
And there is no mention of any downside. They say it even starts quickly, smoothly and easily. But it is carbureted and look at that intake tract. It seems like it would take forever to start.
Anyway:
"Meanwhile, durability concerns led Crane to back off on the boost levels and temperatures for its projected retrofit kits. Smokey's original motors had trick rings, forged pistons, and Carrillo rods, but the retro kits would be bolt-ons for econo four-cylinders. The kit cost kept going up, even as performance declined. Bickering started. In marched the lawyers, and lawsuits inevitably followed. The project collapsed under a pile of recrimination."
Garlits' museum is about 50 miles from me, I've seen the car, Smokey was in my rolodex (remember those?) in my sprint car days, I had quite a few conversations with him, great guy, shame to see what happened to his garage after he passed... being in Florida and from Tampa Bay , you'd run into these guys all the time, still do.
but back on topic.
