- Thread starter
- #301
- 7,619
- 10,337
- Exp. Type
- W2W Racing
- Exp. Level
- 20+ Years
Got A.J. Hartman on speed dial....lol.
explain...?Maybe if it's that expensive and that much work, time to switch to a Coyote/Boss/5.2 setup?
I thought maybe the line in the tank was kinked so I called ford to order a new one. unfortunately you have to buy a whole new tank to get the line, so fawk it.Oh ok. Fuel cell it is!
I'm sick of it....going to a normal setup. Fuel cell/external pump.Can you find a used tank to try?
Check those guy too I've been looking at their fuel cell but too much $$ for now
http://www.radiumauto.com/FCST-complete-with-Fuel-Cell-P893.aspx
I also got fuel delivery issue. Only on one left hand turn going up a hill. As soon as I pass 6000rpm my fuel pressure drop to 30 psi and below.
I've been looking at installing a surge tank to take care of the problem.
http://www.radiumauto.com/FST-R-Fuel-Surge-Tank-with-Integrated-FPR-P348.aspx
is there a left turn before the right?hmmm..... I was trying to figure out why I loss power on one steeply uphill right hand turn.... maybe its some thing related... though its right instead o left....
My setup includes no venturi (also known as an eductor or jet pump) I asked lethal about it and they couldnt tell me if I had one, needed one or if one even came in the kit. They told me to send the hat back and they would go through it and turn it around in 24 hours. Weeks later and after several phone calls they suddenly mailed it back with no word on if it was looked at, if there was something fixed or if anything was even wrong with it. I called and asked and they said there's nothing wrong with it. I asked if both pumps were working and they said "We didn't check the pumps". I asked how does this system work with no eductor and they didn't know. I asked who does know and he said only the owner and he isn't going to talk to you. The guy was a real jerk to me.That sucks about Lethal.
Can you take the fuel hat apart? Maybe something plugged the venturi unit?
When you did your test, did your fuel pressure regulator allowed for some fuel to return to the tank?
You can test it with air with the fuel pump out of the tank. Blow some air into the return line inlet and you should feel a vacuum where you connect the in tank cross over hose.
Here's a picture on how a venturi work. Pretty simple system with no moving parts.
