Front Splitter
I was wondering how difficult it would be to remove the push pins holding the splitter on under the front bumper. They do not look reusable.
They CAN be reusable, but expect about a 10% failure rate.
I get replacements at my dealer. I bring in what I need and he matches them up. No charge.
Dorman and other companies offer replacements.
So how do you remove them? Do you have to push the tabs together on top and then pull through the bottom? It is pretty hard to see how they work the way they sit inside the lower grill opening.
Pretty sure you use a standard screw driver to pull the inner part out and then you can pull the whole pin out.
