FRPP Boss 302 Air-to-Oil Cooler is now available!
4,019
1,966
Gary
I got mine from Gary Yeoman Ford in Daytona for $1100 shipped. Will arrive Wednesday, I on the other hand will be leaving for Daytona/Orlando tomorrow! Does the adapter have a tap port for your temp sensor or are you going to put a tee in for that?
drano38
Wayne
1,130
318
cloud9 said:
ArizonaGT said:
What's the added oil capacity w/ that?
I'm thinking 1/2 quart but I'll let you know when I get it installed! :D Depends on the weather.
Better drop the Boss off Saturday--looks like white stuff in the forecast Monday. Oh well, 4 or 5 days of actual winter in SD isn't bad. ;D
steveespo said:
Gary
There's not a port. I'm going to put a T in for it.
Man, Daytona! That sounds so awesome right about now.....
I have a Steeda shifter bushing sitting on my workbench, will probably go in this weekend when I change the diff fluid.
Also have another "mod" I will post some pics of after the track event next weekend.
cloud9 said:
2012YellowBoss said:
Gary, does it use the FL500S filter?
I checked the instructions this morning and yes it does use the FL500S.
I figured as much, I spoke with some contacts at Ford asking about the difference in this new filter and the only answer I got was both the FL820 and FL500 will work. Then I remember someone posting that they spoke with some engineers at a track event, they did not go into details but were adamant about using the FL500 on the new engines.
Better or different flow, different material or some other reason, IDK but would like to find out someday. I tried a Ford Racing 820 but will switch back to the 500 until Ford Racing makes a racing version of that filter. I was told there are no plans to make one yet, everyone should call Ford Racing and ask to have one made.
JScheier
Too Hot for the Boss!
Note: I just purchased this cooler kit (M-6642-MBA) from Late Model Restoration. They are having a Black Friday Sale, which knocked $100 off the price. I then used the coupon code MODPERF and ended up with $962 shipped!
Wow that's a great deal 8) Merry Christmas to you!
