GT350/S550 Vertical Links
Discussion in 'Suspension and Chassis' started by VoodooBoss, Jul 17, 2017.
  1. VoodooBoss
    VoodooBoss Rick Moderator
    17,788
    735
    Nov 30, 2010
    Just curious if anyone has installed aftermarket vertical links? If so did you notice any improvement in wheel hop and more importantly turn-in on track? I'm not having wheel hop issues but remember replacing the LCA's on my Boss cured the wheel hop and improved the feel of the rear end on corner entry.
    https://www.bmrsuspension.com/?page=products&productid=1572&superpro=0
    Also a couple of videos from FTBR showing the flex in the rear of a S550
    mattlqx likes this.
  2. cj350
    cj350 TMO Intermediate
    25
    9
    Jul 9, 2016
    Central OK
    Never experienced wheel hop but the Steeda vertical links was one of the first things I did. My combination that I am running now is as follows:
    R springs and rear sway bar
    Steeda IRS brace
    Steeda diff lockout bushings (red)
    Steeda adj camber links
    FTBR adj sway bar end links
    No increase in NVH and entry/exit is very predictable. Refrained from adj. toe links and spherical bushings on account of the NVH increase. The IRS brace did wonders really. The forward/rearward movement of the IRS under load is gone. BMR approaches it differently with their cradle bushing lockout kits.
  3. VoodooBoss
    17,788
    735
    Nov 30, 2010
  4. VoodooBoss
    17,788
    735
    Nov 30, 2010
  5. cj350
    25
    9
    Jul 9, 2016
    Central OK
    VoodooBoss likes this.
  6. cj350
    25
    9
    Jul 9, 2016
    Central OK
    1:31 shows the IRS movement the brace minimizes
  7. cj350
    25
    9
    Jul 9, 2016
    Central OK
    Very happy with my setup. The car is neutral and bad fast on the SC2's.
    LERCH and ChopSui like this.
  8. CSL
    CSL TMO Advanced
    118
    11
    Jan 7, 2016
    I had pretty in depth correspondence with James at FTBR about stability of the IRS. He initially tried to sell me the whole kit they offer for the IRS. I tried to pin him down and asked specifically what was most necessary to address the IRS weakness in an open track setting, as observed in the videos posted above. Vertical links ended up not being mentioned in that equation. Instead the emphasis was the subframe, lca, and uca bushings/bearings. I was told the nvh increase would be neglible. I was also told the diff bushings are biggest NVH culprit.
    After some more research I decided to take the plunge with what James recommended. The bushing/bearing upgrade really stiffened the rear. No increase in N or V, but many would subjectively say there was an increase in H. It took a couple of track days to really break everything in. Much of the initial rigidity I felt was stiction in the new stuff that just needed to be worked out. The H is now much more subtle than it was post install.
    I took this leap because I noticed a bit of a wiggle in the rear under heavy load....most often when tracking out of a very fast turn. On track the rear performs awesome and without a hint of wiggle. It is all but forgotten so the focus can be on pushing harder!
    Overall, not an answer to the initial question, but the route I ended up taking to address the topic in question.
    The_Dead_Cow and mattlqx like this.
  9. VoodooBoss
    17,788
    735
    Nov 30, 2010
    Thanks for your input. Can you please post links to the items you purchased?
  10. CSL
    CSL TMO Advanced
    118
    11
    Jan 7, 2016
    http://fulltiltboogieracing.com/2016_GT350_and_GT350R_Suspension_Parts_and_Tools.htm
    I went with the following part numbers: FT522; FT548; FT540; FT530. After seeing how flimzy the front end links are, I also went with FT560.
    I'd send them an email inquiry and ask away. I asked a lot of questions and got prompt detailed responses. I don't know if this mod made me faster, but I do know my car feels very dialed in and confidence inspiring. I also know my car is really fast. As dialed in as the car feels, I think stiffening up the front a bit more will make it even better. I'm pretty sure I'll do the FP springs and sway bars. After that i can't see me doing much else to the car.
    I went with FTBR because I like the quality of their stuff, and they were the most candid and detailed when I started inquiring. They definitely seemed more knowledgeable about the effects of open tracking on the IRS, whereas others couldn't get past a wheel hop discussion.
    The_Dead_Cow and VoodooBoss like this.
  11. ChopSui
    ChopSui Mike
    155
    10
    Apr 6, 2014
    Austin
  12. OPMustang Tim
    OPMustang Tim TMO Advanced
    174
    109
    Jul 9, 2016
    Sunny Florida where it does not snow.
    Our recipe that seems to have worked for several Customers is Delrin Cradle Bushings, knuckle bearing, lower rear control arm bearing. We do not speak wheel hop, so braces are a waste of time and money. Solve the problem buy eliminating the deflection. The stock vertical links are fine and sometimes its better to let things have some 'freedom' If it is a track only car you can do the aluminum cradle bushings but honestly the delrin locate the cradle. If you feel the need you can change the differential bushings but that does not influence handling in an IRS, possibly wasted motion through the axles. Again some deflection helps parts not break. Poly/Delrin/Aluminum would all be effective but not a must. Material choice is subjective based on NVH tolerance and true purpose of the vehicle.
    mnmike59, The_Dead_Cow and VoodooBoss like this.
  13. The_Dead_Cow
    The_Dead_Cow TMO Intermediate
    34
    30
    Feb 16, 2017
    Gilbert, Arizona
    Thanks for posting your experience. I've been thinking about doing this for the same reasons as you. I'm relieved to hear the NVH wasn't increased too much.
    Did you do the removal/install of the bushings yourself?
    If so, how did it go? Any tips?
  14. CSL
    CSL TMO Advanced
    118
    11
    Jan 7, 2016
    I did not.....it's pretty involved and not my area of expertise unfortunately. I am fortunate to have a great shop local and my tech is a good friend who is experienced in racing and building racecars. He took care of it and did spent about 8 hours on it if I recall correctly. I do know that FTBR can give you a good idea of install time for what you intend to do and will also help with tech support.
    The_Dead_Cow likes this.
  15. The_Dead_Cow
    34
    30
    Feb 16, 2017
    Gilbert, Arizona
    Thanks for the input. I'll have to give them a call when I get closer to pulling the trigger.
    CSL likes this.
  16. Eritas
    Eritas TMO Beginner
    Oct 11, 2017
    FL
    +1 CSL. The fact the Mustang GT4 and new FP350S use stock vertical links suggests they're not necessary.
  17. Black Boss
    Black Boss TMO Addict
    1,275
    268
    Sep 29, 2012
    Michigan
    +1. Adding too many solid bushings may cause bind. For my build I went solid for sub-frame, diff (FRPP) and forward LCA (Cortex).
    Eritas likes this.
  18. BigTaco
    BigTaco TMO Race
    499
    50
    Nov 27, 2014
    Black Boss,
    do you have the Multimatic adjustable rear control arms?
  19. Black Boss
    1,275
    268
    Sep 29, 2012
    Michigan
    No -- Stock:
  20. Black Boss
    1,275
    268
    Sep 29, 2012
    Michigan
    Just remembered, also installed the FRPP solid Toe bushings in the lower arms too.
Share This Page
