S550 Honey Badger GT350 Build Build Thread Profile - S550 Mustangs
Modified GT350 called the Honey Badger
yep. trans is a tank and I don't hesitate recommending it at all. And after having it apart and getting to touch basically every part of it, I'm an even bigger fan of it. It's light, easy to work on, and durable AF
ust realizing I have a lot to catch up on - I completely forgot to close the loop on the trans.
So as mentioned in a previous post, at the Nov event, the trans started getting really hot. It's ran dead cool all year - so overheating in 60 degree weather was weird. After verifying the pump and fan were working, I popped the fill plug off to check oil levels. A bunch of sparkly oil poured out. weekend done.
So once I got home, I pulled the trans to see what happened. Once I got it on the bench and started disassembly, I didnt make it very far before the problem was clear.
There's supposed to be a cage around those steel balls. Boooo
I took it down further and found metal shavings EVERYWHERE. Inside all the bearings, inside the shfit rail, I mean EVERYWHERE.
I also found one of the bolts was snapped and one loose. Man - this engine isn't even a voodoo and its still rattling everything apart.
I went all the way down. I reallllllly didn't want to put it back together knowing there could be metal circulating.
I ended up replacing all the bearings(ouch - those suckers are pricey) and all the seals/o-rings. All the gears looked MINT. A teeny bit of wear on the input shaft dog's but everything looks great. This is one stout like bad mama jama.
All back together (sans bell housing).
I also did some quality of life upgrades while I had it apart. Removal resulted in a horrific mess of oil and brake fluid. I got myself some dry breaks so it comes apart cleanly and you can remove without having to spend an hour cleaning afterwards.
View attachment 101041View attachment 101040
Off camera I also cleaned the lines and cooler. The lines are PTFE, so they cleaned up great. The cooler and pump took a bit more work. I ended up hot tanking, ultra sonic and pressure washing them. I ran some oil through them separate of the trans and it came through clean.
She's ready to go back in. Just need to finish up reinstalling the oil pan. I ended dropping the k-member to re-seal the oil pan. It's had a super slow leak all year from where I missed some RTV when I installed it. Used the opportunity to inspect the bearings, cylinders, etc. All good there.
What dry-break connectors are those? They don't look like Staubli's.
Looks like these just from the disconnect sleeve and colouring. I can see upgrades to my trans and diff oil cooler system in the near future.
Place your bets to see if i was correct.
Yep. They’re the ones GAR944 mentioned. Didn’t go with Staubli’s since these aren’t brake lines. I’ve been tempted to do those some day. But they’re so bloody expensive.
Ding ding ding!
Okay - got the plumbing for my coolant crossover test worked out. To recap, I plan to record the water temps at the back each head with no crossover, then open a passage between the two (similar to popular "crossover head cooling mods" on the market). After getting data on that, I am going to test my own version that plumbs cool water from the front of the motor into the back.
crossover mod with ball valve to be able turn on/off that's reachable with the intake on.
My custom setup for supplying cooled water that will run under the intake. Got the idea from late model and dirt racing where they've begun running external coolant lines to help ensure all parts of the engine have cool water.
These will be in the back of each head to measure temps. Only hard data with this test
This is awesome....to be clear, you are plumbing water into or out of the back of the heads....?
Into the back of the heads
Interesting....why not out of the heads? It may just deadhead against the factory flow up out of the block into the heads.
That's how we did it way back when, every additional tap was an out, but maybe the flow path is different than what we had with the SBC's.
Interested to see what you learn from this. :)
Somewhere on here or YouTube Shawn has a great video where he walks through the water flow in the Coyote. Basically, the back of the heads are getting the water last, resulting in that area getting the water while its at the highest temp. My hypothesis is that removing water at that point would just reduce volume of water cooling the heads by the intake valves that comes out of the front heads without reducing the temp of the water cooling that part of the head.
But you could be right - the higher pressure in the back could cause it to not see any of the fresh water. I should plumb an option that pulls water out and into the swirl tank. I'll work on something to test at the same event. The trick with that will be getting overall flow right. I discovered that if you have too much flow out the front of the heads, it doesn't have enough time to cool properly. At least that's what I think happened when I went from dual 12an lines to 16an lines on the outlets.
Pulling water out the back just might balance that front to rear issue....but who knows.
Have you talked to Shaun about this? I bet he'd be interested in this process.
This video is why I did not do the head cooling mod when I built my car. In the video, he does say that he thinks that putting cool water in would work, but this may have been an off the cuff remark.
Very interesting experiment!
I haven't yet. I've only been coordinating with @5.2 liters of democracy so far. I'll send me a note and see what he thinks.
ah ha! so he did give me the idea for the re-route, not just the theory that the head mod does nothing. I'll have to reach out
I remember seeing that video....looks like you're right. Water "into" the back of the head.
Got lots of trimming to do and some venting (especially down rhe trans tunnel where the exhaust is), but the latest project is shaping up
Super curious to see how this affects top speed
Finally got my steering wheel hub wired up and programmed. been putting it off for quite a while with so many other things to do and knowing it was going to take a lot of trial and error. But finally get everything working today!
Little preview of my redneck "push to pass" feature
Having a PDM is so damn cool. there's just so much you can do
Ford recommend a 5/16 restriction in the outlet port of the passenger head if you're bypassing the heater core to insure correct cooling flow.
Page 10
yep - that sounds about right. I wish they'd publish overall flow number recommendations. I run an electric water pump that uses a controller to adjust speed based on temp instead of a thermostat. So ive had to do trial and error to find the right hose sizes.
So far dual 12an into 16 wye has been the best. I'm currently testing a 16an + 12an into 16an wye.
I think the OEM hose was 1.5in diameter? but the thermostat reduces flow a good bit.
FWIW The meziere pump I run is 65 gal/hr. In fact, all their pumps are 65 gal/hr. so maybe that's a magic number?
Might be an interesting test to put a potentiometer on the pump and manipulate the flow on track to see what's most effective?
The controller I have is essential a little computer that controls a potentiometer, so I can run it at a bunch of different levels. it's been super helpful. What i've discovered is that the diameter of the outlet hoses matters a lot more than the speed once you get up above about 60%
The Pierburg is about 40GPM at 0.85 bar and 58GPM at .55 bar. I wonder what pressure that 55gpm from Meziere's specs is calculated at.
