Hi Guys,
I NEED a solution. Swaping oem ecu to MOTEC. So EPAS should be ok with the @cortexracing unit, but I dont know what to do for ABS. Looks like the OEM unit need can bus feed. I bought the FP350S ABS unit but looks like we'll run into the same issue. We would either need to either find a way for motec to talk the the ABS module, or to find a standalone system that does not require canbus (I know about BMW units, but I already have the FP350S module).
I cannot install a Motorsport ABS system as per the regulations.
The FP350S connector is not the same as the OEM unit so I had to find one and modify it a little to make it work.
![Connector.jpg Connector.jpg](https://trackmustangsonline.com/data/attachments/91/91605-d1c4e41bc94a68cbfffabea87f2136c1.jpg)
![ABS unit.jpg ABS unit.jpg](https://trackmustangsonline.com/data/attachments/91/91604-c2f4ce26fb3ff716ece9afb5dc3bb719.jpg)
