Installing the M-17757-MB front bar
680
215
Dean,
check with Watson Racing, they may have a template. www.watsonracing.com
While you are at it, I would purchase the radiator enclosure from them that is designed to work with your tubular front bumper. It is super effective in helping to keep things cool.
I would ask for John Phillips.
Also,
Cortex racing in Sonoma may have a template; they installed my bumper with no issues.
369
146
Waco, TX
Dean,
Also,
Thanks and I definitely will. I have the enclosure already. Hopefully they can help.
899
546
This is the template I got from @Tri-bar a couple of years ago. Update: The template is marked 2010 - 2012.
  • Ford Tow Hook Bumper Template.pdf
146
Waco, TX
2014
Here's what John at watson sent me
It’s fairly simple to locate the trim area by mounting the fascia over the tow hook loop mount and tapping it with your fist to make a witness of the area, this will give you an area to start from then its trim, test, trim, test.
Tucson 302
2013 Black LS #439
2014
That's what I basically did for the rear bumper bar and tow hook
