..Kenny Brown Suspension
cobrarob
11 Shelby GT500
555
130
new york
Hey guys. Been a long time since I posted. Question on KB setup..
Currently sitting at 14 1/2”f/15 1/4”r ride heights(center hub to fender lip)with rlca almost level(1*) pointin up to front..
Thinkin of lowering the car but will put rlca pointin down, will that cause issues? Thanks Rob
599
537
No, that's about where they run, Just a FYI, keep an eye on the axle panhard mount. The wield on the bottom of the mount can break, and take out the Kenny Brown mount with it. that's where mine failed.
cobrarob
11 Shelby GT500
555
130
new york
@Tri-bar Woa thanks for the heads up, will check. I actually just switched to that updated bracket from his old style(2lower holes) which I had on the car for years.
Had an off at VIR and cracked stock brackets but his bracket was ok, but switched anyway.
Looks like you’re not running the lower roll center bracket anymore? Or just in the meantime till new one comes in?
cobrarob
11 Shelby GT500
555
130
new york
Yes read your post on swapping out systems, very informative thanks. I put that littl boss swaybar on with a 325 spring out back but didn’t like the feel. Mainly because I had a bad alignment setup which I didn’t realize till I got home.
Will try again at VIR in April
599
537
A bad alignment car ruin your whole day, I like 3.5 camber, 7+ caster and 1/8th toe out.
