- 17
- 0
I try to keep my car immaculate but i just oticed swirls and scratches on my hood decal apparently from using quick detailer with a towel on it. Any idea how to fix this?
Save yourself some headaches and get quality microfiber towels.dale5150 said:Mine is a RR 12. I used a very soft old bath towel that I have used for a while. That decal is going to be a PITA!
DEye said:G'Day
First post,
I use BacktoBlack for the Black plastic bits , but not sure about what to use for the hood/Boss decals ?
Should you wax/not wax the decals ?
Thanks
Don
2012 Yellow blaze #663
+1 on the VRT. Back to Black....ForceofWill said:You can glaze/wax over the 2012 decals no problem, they're already shiny and don't streak. I'm not a fan of back to black, I don't feel it really does anything. I'd look into VRT from Adam's.
So you used orange and one pass 105 and one 205 on the vinyl? any before and after pics?racered302 said:I've been to 2 car shows with this car a got crapped on twice. First time I posted about it above. The second time was 2 weeks later, I'm done with car shows. This time, I was going to get the stripe painted on there if I couldn't get the stains out. I figured I'd be more aggressive for that reason. I used Meguiars 105 and 205 with a DA, white or orange pad, I used orange. Unlike the Groit's there is no filler, so it's not going to wash away, which I discovered after my post above, it's just polish and it works and has a decent amount of cut. I didn't go for 100% but it took the minor swirls, scratches and stains out. I've used this stuff for a couple of years too smooth scratches out of my paint but now I found another use for it.
what did you put on them to protect them? I found Zanio has worked well for me. currently testing the 22ple on them. not sure if the 22ple will bond with them or notracered302 said:Actually 2 with 105 and 1 with the 205. I was to pissed to document anything. I would have peeled the stripe off if it wouldn't have cleaned up. I was pleasantly surprised.
Justin said:what did you put on them to protect them? I found Zanio has worked well for me. currently testing the 22ple on them. not sure if the 22ple will bond with them or not
