Motul MoCool
4,019
1,966
Has anyone tried MoCool by Motul to help reduce coolant temps? I just saw it at Lime Rock this past weekend and picked up 500mL. Says reduces temps 15 to 30 degrees C. Also claims compatability with all coolants. Just checking if anyone has used.
In for the results.
Snake oil as in you tried it and it does nothing? Or does it cause problems and clog coolant passages etc?
Tried similar products. Miniscule to ZERO measured differences. Kind of like stereo cables that cost $50 for a set or "better" ones that cost $500 a set. The dude that pays $500 SWEARS by the difference. Put him in a blind comparison test and he picks the Wal Mart cables.
(I doubt it would harm your engine in any way... just don't think it will help either.)
1,255
GA
steveespo said:
Thanks guys, guess $13 wasted, no hot dogs at the next track day for me ;D
Probably best anyway. My first track weekend I ate a greasy egg and cheese sandwich for breakfast and then proceeded to go out and do 60-0 braking and cone slalom exercises. I realized that maybe it was a bad idea. ;) Now I eat snickers or granola bars during the day.
LOL, one thing I hate is bedding in the brakes. Makes me sick everytime :(
OLOABoss
AKA OLOABoss
roywilk1960 said:
All of the engine builders I have delt with say run straight water, distilled, water pump lube, Napa 13 or Konklin, and no other additives.
Water is definitely a better heat transfer medium than water + antifreeze. The downside to straight water is a lower boiling point than the antifreeze/water combo. If you run straight water I would run .Pencool 2000 as the sole additive skip the NAPA junk.
Peter
The product you are referring to is Water Wetter.Yes it does work.For the best results replace your antifreeze with distilled water and a water wetter product.This will bring your temps down 10-15degrees. This what Miller Motorsports does in the track attack cars.It does work with your antifreeze as well.
OK, someone school me on Water Wetter.
How often do you have to change it or add more? For street and track use, is it best to add to the anti-freeze or use just water and water wetter?
What is the downside to using Water Wetter?
I know this next question is purely opinion, but which is the best name brand?
