I’m running it on my 2014. I had to clearance the pinch weld seam on both sides - roughly in the area of the arrows in this picture. I’m running the Watson solid engine mounts so no flex - may have to grind a bit more than I did if you’re using stock or urethane mounts.Has anyone installed the GT500 pump and pan on the S197? I see where ford says in the fine print:
***2011-2014 Mustang cross member will require slight modification for clearance***
I am wondering how slight.
![IMG_9485.jpeg IMG_9485.jpeg](https://trackmustangsonline.com/data/attachments/96/96270-be7416310620b6f25a53017250176bcd.jpg)
