wrong spot
Presumably it'll work fine. Two things, though. First, you don't need 650 brake fluid for the clutch - nothing in the clutch circuit runs remotely as hot as the brake system. You could run a value-priced DOT4 fluid in the clutch circuit and it'll be fine. Second, I had some aftermarket brake parts on one of my Fords and they started to leak brake fluid after Castrol reformulated SRF (they added "React" to the name and changed the formula). Turns out not all rubber products are compatible with all brake fluids. Watch for leaks after the install - probably not an issue, but it's worth being careful.Want to get this installed before my next event at road America. My question is I am running endless 650 fluid. Will that work with this kit?
I did not know the clutch and brake fluid are shared.
Thank you!
Andy
