Power steering fault
Did a quick search to see if anyone had a similar issue as to what I experienced a few minutes ago, no such luck. I turned my car on and it stated "Power Steering Fault" and wouldn't let me move the wheel at all. I turned my car off and waited a minute before turning it back on, and the message/issue went away. Has anyone else had this happen?
jneary
Performance Fords
323
Norcal
Have not seen that one. Matter of fact, haven't seen any faults of any kind come up. So it wouldn't let you move the wheel at all or the wheel was just really stiff?
John
not Ford related, but my father just had something similar happen on his 2007 BMW M6. in his situation the steering worked normally but the light came on and the code was for the steering lock. In his case, BMW did a good will warranty on it because it could have locked up the steering while being driven.
your issue might be the steering lock OR something to do with the electronic portion of the rack / column?
I am wondering if it was just a one time glitch, not sure if it may have even stored a code. Could always have Ford read the ECU to see if anything has come up.
