- 107
- 0
Hey, how often are you guys changing your rear diff fluid? After how many track days/weekends??
cloud9 said:Did my first after 4 hours and then every 12 hours after that just like the supplement outlines.
From page 38 of the supplement:PeteInCT said:I'm probably just not paying attention, but where's the maintenance schedule info - supplement or otherwise ?
Correct it doesn't hurt to use it. It's added in the Torsen diff to make it run quieter for street use. It is needed for the non Torsen diff but the manual doesn't specify which diff needs the modifier. I've confirmed this from both Torsen and Ford Racing.ChuckP said:"FYI the friction modifier is not needed for the Torsen diff."
I don't believe that little detail is mentioned in the Boss supplement. Not that it hurts to use it...just not needed.
5 DOT 0 said:Correct it doesn't hurt to use it. It's added in the Torsen diff to make it run quieter for street use. It is needed for the non Torsen diff but the manual doesn't specify which diff needs the modifier. I've confirmed this from both Torsen and Ford Racing.ChuckP said:"FYI the friction modifier is not needed for the Torsen diff."
