Rear diff whine after track sessions (Dark Horse) – normal?
4
4
PNW
I’ve started doing more track days and I’ve noticed something consistent after sessions:
  • After coming off track, I hear a continuous whirring/whining noise from the rear of the car. No vibration, no grinding, just a clean whine that goes away with heat.
  • It’s most noticeable at low speeds rolling through the paddock
  • Sounds almost like a gear or electric motor whine
  • It fades away after a few minutes once things cool down
  • I don’t hear it during normal street driving
  • Has never gone into 'limp' mode, and no dash/engine lights/faults
Car is otherwise stock, curious if this is:
  • Normal diff heat / fluid behavior on track
  • Something others have experienced with these cars
  • Or an early sign I should be looking at fluid / maintenance / cooling
Would also be helpful to know:
  • How often you guys are changing diff fluid with regular track use
  • If anyone has upgraded fluid or added cooling and noticed a difference
This is first mustang I've ever owned- Appreciate any insight, just trying to stay ahead of anything before it becomes a bigger issue.
Does your Dark Horse have the Handling Package? I’m guessing it does and you’re hearing the electric pump for the differential cooling system.
