Dark Horse Factory Adjustable Camber Plates
By trying to get screw out the top. Could not do it can’t see all 3 you have to go through the strut tower hole. Some say you can with a ball end hex and get to them. I did not see that happening do spent a few hours on it then threw the screws away
Watching Vorshlag videos with Dark Horse. Very interesting. -3.5/-2.0 on one with vorschlag plates and aftermarket arms (where you might get more camber from) and another with -4.2/-3.2. They don’t cut the holes because that’s illegal under certain rules. They get camber from 4 places top of strut bottom of strut ride height and hub/wheel assembly to strut.. Different ones legal/illegal depending on sport not sure which is which. Easiest top of strut but obviously. TT obviously loves huge amounts of camber and huge sticky tires. The -3.5/-2 seems like a proven amount of camber that can be done on possibly a stock DH with plates. Might need the vorshlag plates. Not sure but i’ll find out (they say -2.5 over stock which is about -1 i think )
Cutting top of strut so it fits under strut tower seems like a good idea vs cutting tower. It all depends on what rules you plan on going by. Since i don't have a real plan yet i don't know what direction yet
I see they sell a cutting fixture so assume thats the fastest easiest and cheapest route.
So this still circles back to how much you can get on the factory plate. Looking at mine cutting will be necessary either the threads or hole
Sorry for the long ramble but i thought their numbers were interesting especially compared to the ford factory numbers
Yes. I am very curious about that. It would be helpful to know before spending money for aftermarket camber plates.
I don't even know if the strut hole interferes before the Ford camber plate runs out of room, or if the Ford camber plate runs out of room before the hole in the strut tower stops the strut movement.
It would certainly be cheaper simply to cut the hole and keep the Ford camber plates. Just the cost of a cutting instrument. And I am not sure looking at it that it needs to be a bigger circle. Why not just some minor clearancing to get full adjustment on the camber plate?
Nevermind, found it.
Thank you, @mikeD4V !!!
:thumbsup:
How many degrees of camber are available in the Ford stock adjustable camber plates that come on the Dark Horse, if I buy the strut tower cutting fixture tool and open up the strut tower hole?
Here is the stock Ford plate (this picture comes from Vorshlag). I do not know what his comments, 1.5° and 0.53 inches mean in terms of what camber setting you can get on the front. Can you do 3.5° for track day?
Quote from another forum: He said same, drop the strut. "Look closely at my picture. There are 3 countersunk bolts that you loosen, then slide those buggers all the way in." The other poster was not sure about the "set pin" all the way to the left.
Ford Performance sells them separately.
and they say
  • Original equipment on 2024-2025 Mustang Dark Horse & 2021-2023 Mach 1 Handling Packs
  • Fits 2024-2026 Mustang Dark Horse
  • Fits 2015-2026 Mustang EcoBoost & GT
  • Fits 2015-2020 Mustang GT350 & GT350R
  • Fits 2020-2023 Mustang GT500
  • Camber adjustments up to -2.3 degrees and optimized rubber durometer provides excellent handling tunability
  • NOTE: Requires all hardware to mount to the strut spring assembly. Additional assembly hardware may be required.
I just don't know if that means -2.3° negative is the maximum camber or if that is the range of adjustment from a starting point that is not 0° ???
For comparison's sake, only, the Vorshlag plates state, "Camber adjustment is about 2.5° of added negative camber over stock."
Because Vorshlag advertises this 2.5° "over stock," and we all know you can easily get -3.5° with the Vorshlag plates and cutting of the strut tower (or the bolt on top for clearance, which is an appealing idea).
Why does Ford even install those three screws? I do not understand. What is their purpose?
I posted pics of my towers i’ll post them again
Don’t think i’m gonna get much more without cutting something
I’d be interested in the hub wheel to strut adjustment vorschlag said all mustangs have this i’ll have to crawl under and see that would increase the camber available
Have a look at the bottom of page 1 of my old thread, See @GTP comment July 6 about elongating the upper hole and @Stan Whitney comment Dec 13 re "approved" factory repair procedure also.
While this is possible, the issue is wheel clearance to strut, 305's may be already as close as you can go so no point.
This was my issue. 285 on a 9.5 and i could max out an aftermarket strut and get close to 5, ran 4 and was happy . Going to a 305 on an 11 and i had to dial the hub/strut leg back and ended back probably somewhere in the 2's with the camber plate already maxed.
Had to go radical to get it back. Now back to 4 after a new alignment. Everything is a juggle when you start getting to the extreme end of the scale.
There is a reason the Ford race cars run fancy stuff.
View attachment 109341View attachment 109342
Ahh yes may be maxed out already. Vorshlag uses 3mm spacer min clearance to the strut. Is that the DHR camber plate? Or which one is it? They seem to like -4+ as well
