Rear Gear Ratio
Has anyone swapped out the stock 3:73's? I've read about Fox Bodies with stock Coyote motors and steep gears (4:88 etc) running high 10's in the 1/4 mile. The Boss 6 speed makes the rear gear close to a 4:10 if compared to a Tremec. It just seems like a cheap mod that would not void warranty. I'd really like to try 4:30's with drag radials. Is there a speedo gear to swap out to correct the speed or must it be done by the computer?
3,946
1,699
Make sure you take into account tire size. Stock wheels/tires are 27.1" tall, If you go to 17 or 18" Drag tires you can reduce height and effectively lower gearing. Tire rack has revolutions per mile in the specs of the tires they sell and you can find calculators on google to run the numbers.
8,697
2,686
Also if you're talking about drag racing, you'll want to take into account your max speed in 4th and 5th when considering your gearing--but you will be doing a LOT of shifting with a shorter rear gear.
The only 19" drag radials I've seen are taller that the stock tires. I lean toward keeping the stock 19" wheels because I like the stock look. The M/T tires are 28" tall. They might be better paired with 4:30's. Maybe I'll end up being the test mule. I just hoped some one on here had swapped gears. Has anyone used the the 28" tires with the 3:73's? If yes, what was your RPM through the traps. I assume you be in 4th gear.
