isrboss
I have been reading members talking about the KB rear roll center relocation kit, and finding that Steeda also has a similar offering. I read that you can't fit FRPP relocation brackets with the KB, and I don't even care to read up on the Steeda unit.
Here is a picture of the angle of my BMR panhard with approx. -1.3" lowering.
You can see I still have a slight upward angle, and I have read it should be level. Now Is there something special about the KB kit that i'm missing? When I look at the panhard chassis mount, I see at the least about 1" of area below the original mounting hole that could be drilled or slotted. If the idea is to get the panhard as close to level, could we not just simply slot the chassis mounting point?
If this is possible, I don't see why any relocation bracket etc. couldn't be used, while getting the panhard close to level or parallel to the axle. Maybe I'm missing something here, so please educate me.
The other question I have is rear sway preload with driver in seat. I was thinking of shimming the axle mount point of the side that will want to move away from the axle with the driver in the seat. Does anyone have insight on this, is it possible or worth it with the solid rear?
Thanks guys
Thanks guys
