captdistraction
GrumpyRacer
2011 Mustang Steering column (minus PATS receiver). Includes column and one key, upper and lower (engine) steering shaft, turn signal stalk, and firewall bearing/seal assembly. Steering lock has been removed for racing use. $80
NRG short steering hub adapter (6 bolt / sparco 2.75" pattern) - NRG SRK-175H - $75
1" 2.75" x 6 spacer, gold in color with bolts - $10
NRG Steering Wheel Quick release - Gen 2.5 (with 2 contacts for passthrough) - Red Anondize- RK-250RD - $75
All of it? $220, at that point you have a setup that places the wheel where the oem one was, just select your wheel of choice. The bright red and gold release optimizes visibility and safety should a third party need to disconnect the wheel.
