S197 SLA Suspension System from Cortex
I guess my point is just take the whole door off before you put the car in the trailer. Rigged up some stuff to get mine hanging on the wall of the trailer when not on the car, and it secures on the car with some 5/16" pip pins after knocking out the factory hinge pins at the front (idea courtesy of Rockwells)
That's not a horrible idea.
Holy hell, you guys drive your cars into the trailer? I wasn't aware that one needed a special permit to buy and operate a $250 HF Wireless winch :) I tie down to the t-hook holes in the subframe, so i put the straps on first, hang them over the splitter to keep tension on them, hook the winch rope to the front tow hook and pull the car in.
Bonus for @Fabman, you can use it to winch that toolbox up into the trailer first.
DaveW
DaveW
We have a winch....never used it once.
DaveW
My car is WIDE.....it barely fits between the wheel wells. Like 1/2" clearance on each side.
Trying to pull it up with a winch would be tough to keep from crashing the carbon splitter. Someone would have to walk up with the car holding the steering wheel anyway so might as well just be in the car.
Besides, once the tool box is in the trailer you can't run the cable out to the car because the toolbox is in the way....I've looked at all this already and its just easier to drive it in.
Not that any method is wrong, nor that we would ever be at the same event because geography for you to see it yourself, but I will try to take a photo or video next time I load. My car has 3/4 inch on each side and I have an entire tire shop and rolling speed shop in the front of my trailer and make the winch work. Rope goes right under all that stuff which is on wheels just like a toolbox. And wireless remote so you walk next to it and tweak steering until it's lined up.
All out of necessity, because autocross is silly, but it's cheap, so I do a lot of weekends and need the loading to be efficient and quick.
Way easier (for me)than twisting my back or knee climbing out of the car inside the trailer. I also usually load alone so I would be likely to drive the car into the fender of the trailer without a spotter.
If you ever try it though, invest in a synthetic rope for the winch. The wire ropes are a nightmare spooling and unspooling all the time with varied load and tangle into a solid mass of disaster.
Video!
You also can get flat strap winches and in my experience they are even better. The strap winds onto the winch flat so there's no chance of any foul ups.
Just a odd thought, If you are not using a winch, maybe you could use it to get out of the car?;)
But seriously, this is fastest this way, I drive outta the shop and right up the ramp and my son ties the car down and I climb out. Done.
It would take way longer with a winch. I have loops welded to the bottom of the car so he just clicks the snap hooks on and boom, done.
Solid straps on the back set the depth into the trailer so the wing just clears the tailgate/ramp and ratchets on the front tighten things down.
Takes like 3 minutes.
Finally got the shocks. Some sort of miscommunication about canister hose length, Cortex asked me how long and I said 4 inches longer than the S197 MCS struts which turned into 500mm length which is 650mm SHORTER than S197 struts. I am kind of done with Cortex, but I talked directly to MCS about getting correct hoses which (I would pay for) and the lead time - as usual with my dealings with MCS, service is excellent and they can turn them in a week for me, but....
I test fit the shock this AM and if I mount it hose up, I can put the can in the back part of the fender well in the air gap between the fender and frame. I can make a rock/cone protection shield for it and can adjust by just turning the wheels. Long term, I wanted to get them out of the engine bay anyway because heat, even with all the venting it is crazy hot/heat soak in there with all the sitting we do at autox. And with the struts, I could adjust all the things under the hood, but now I will have to jack the car up to do rebound anyway, so reaching into the fender is not a big deal. If I don't like it, I can send them for longer hoses in the off season.
I realize this is a bit of a "how long is a rope" type question, but @Fabman @ArizonaBOSS how much droop travel do you have? Attached photo is at full droop and measures 1.5" from my desired ride height. Seems like I was closer to 2" with the struts, but I forgot to measure.
Thanks in advance for any info.
Dave
Dave
I’m not at the shop so best I can do at the moment is this comparison.IMG_2022.jpegIMG_2020.jpeg
Thank you. I think I need more...I have plenty of space in bump before bottoming the shock, so I might look at lowering the upper mount.
I am pretty happy that I paid almost $4k for what are essentially the wrong shocks on top of almost 5 figured for the system itself that I have to now re-engineer.
DaveW
DaveW
Just run the front end 1/2” lower. If you need to you can use the middle hole on the lowers (that’s where I am) to get the front lower and keep the LCA angles where you want. I would caution against re engineering anything until you’ve worked with what is already there….2” is a lot of droop. Think you need all that?
I added Cortex's SLA to my S197. Looks great and looking forward to getting it out on track. My last step is braking cooling. Looking for ideas to mount brake ducts (I have 2) to the Radial X Spindle. Any suggestions or pictures?
Cortex has made some in the past, might want to check with them.
DaveW
Dave, give me your eye to eye shock measurement at ride height and full droop and we can compare it to my JRI shocks. I don’t think I have any more droop than what you are getting but we can find out.
Anybody here with the RadialX spindles have trouble with the bumpsteer stud getting loose on the spindle side? I had a pop show up on course the other day, checked it out and found a little play in that joint. I cinched it down and it was quiet for a bit but popping again (no play) by end of runs so I torqued it down to 100ft instead of just leaning on it with a shorter ratchet.
That lasted just a few runs. Still no play but definitely an occasional pop noise. I haven't checked it yet this afternoon but when I did yesterday, it definitely tightened up 1/4 turn and guessing I will find the same.
I don't have one here but I guees its time to replace the nut and maybe double check I didn't screw up the bore on the spindle. I don't remember if it was tapered or not.
DaveW
DaveW
No issues with this that I am aware of (so far), but things do wear and it could be a good idea to do a preventive replacement. If you're not already doing it, get a bright-colored paint pen and witness mark all of your fasteners once they are properly torqued. Then you can do a quick visual check each time you are "in the area".
@SVTMatt Sorry this post is bit late. I had the same challenge and ended up making some deflectors on mine. There should be pics in the late stages of my build thread. Ran 4" "round-to-oval" transitions from the brake duct inlets in the front bumper, and trimmed the fender liners to allow them to poke through. That air then hits deflectors and shoots into the wheel barrel/brake rotor backside. I used some generic metal strip w/ holes from Home Depot Motorsports to attach to two holes on the swaybar mount where the drop link attaches. The drop link bolt can be one of the fasteners that holds the deflector bracket to the swaybar bracket. I just fabricobbled this stuff together, but it's very effective.
Inlet photos (fender liner removed): https://trackmustangsonline.com/threads/boss-302-race-car-build-thread.5404/post-227063
I will see if I can find some photos of the deflectors themselves; pardon my dirt after a few seasons of hard use.
