S550 AIM Solo 2 issue resolved
2,203
1,067
Bay Area
Hi everyone,
I have been working with AIM on their data logger and since we have to plug ours into the OBD and unplug it after we use it I asked them to make me a custom harness so I can put in a switch. I will be adding a hardwired switch somewhere within arms reach ( I have T-REX arms so it will be close) HAHAHHA!! Therefore, we can turn it on and off so we can still gather our data. I confirmed with AIM that this will work with all of the 2015+ platforms.
Once I have it installed I will post pics. Then I will talk to AIM about a group buy. Please let me know how much interest there is.
52
SF Bay Area
@byronj I'm thinking about getting a Solo 2 DL and saw your post. What's the reason to have to unplug it after each use?
Is the data channel support good for the GT350?
I've been using a Bluetooth OBD reader connected to RaceChrono on my iPhone, but the refresh rate is so low that the data isn't very useful--throttle info is super jumpy at 1 Hz refresh rate. I'm hoping the Solo 2 DL has a good refresh rate given the hard-wired connection.
Thanks
31
52
SF Bay Area
Update - after a lot of back and forth with AIM and some testing. We finally got it to work.
@Hobdul the reason for the switch is to turn the AIM off when the car is shut off.
Cool, thanks for the update. If I bought a Solo 2 DL, do you know if it would it work out of the box? Or would I need a custom config file from AIM support? Looks like they show an S550 profile as supported, but sounds like we need a GT350-specific profile. Thanks.
2,203
1,067
Bay Area
We need a GT350 specific cable that plugs into the OBD. The one I had AIM make you can wire it to a switch. Ive been relocating and might see my car this week. If I do and I remember Ill snap a pic how I set mine up
98
129
Charlotte
Thanks for paving the way! I’m in the process of switching from a TrackAddicts/GoPro set up to AIM for my GT350. If you could, I would certainly appreciate the part number(s), terminology and correct contact info.
2,203
1,067
Bay Area
There is no PN . It was a custom piece I had AIM make for me. Call AIM ask fro Cameron and him to build the GT350 harness like he did fro Byron. If he doesn't remember then hit me up and Ill help you out.
