Ford installed these wacky drain plugs in our S550's. I want just a hex bolt like every other car but the clever guys at Ford give us things that fail and things not immediately available. These plugs are $50bucks for fancy ones to the $10 from Ford. I found a cheap plug by accident. This Dornan Plug #097-826CD is $6 at the autoparts store. Because you can't just put a hex bolt in your oil pan it is a good idea to carry one of these as a spare. I'm a safety wire nut so I drilled a hole in the flange to put wire through.
