- 22
- 0
Under normal low rpm shifting its pretty smooth shifting into 2nd and 3rd. When I shift from 1st to 2nd to 3rd at high rpms it becomes harder to shift gears. What is causing this to happen and how can I correct this?
Randy said:I appreciate all of the feedback. This forum is great.
ace72ace said:Is this under aggressive, high rpm shifts from 2nd to 3rd?
+1steveespo said:MGW is really a big improvement when it comes to the 2-3 shift. The positive centering spring and precise gate alignment make that shift very accurate. 3-4 is also very positive. My 1 minor gripe is the low speed 1-2, you have to be very forceful in maintaining left pressure and pull the lever firmly down into gear. Not really a problem but a change in habit from the stock shifter. On track I have complete confidence which gear I am engaging. 100% better than stock unit.
