The Wind Tunnel
866
909
So Cal
...Well, at least in a figurative sense. I thought it might make sense to have a nonsense thread to BS about stuff without making a full thread on it.
I'll start, because I just got done with a project.
I have a 2020 S550 HPP Eco in CAM-'C trim. My brake package with the GT brakes with 14" front / 13" vented rear with 4 piston calipers on the front. It'd be a pretty capable system except for the assinine 'reverse venting' on the discs. I put EBC blue pads on the front and called it a day. That's good enough for parking lot duty. In some ways, having discs that don't cool might be an advantage if it's only a 60 second run? I don't know. It's still stupid.
Ford change the disc around a couple years later and there's always 2 piece stuff, so I could have gone down that road, but, instead, I grabbed a take-off Brembo kit on Ebay from Shelby a while back...a long while back. I figured I bought the EBC blues; I might as well burn them up. The Blues were a good pad with quick bite and good stopping power. They were noisey as hell initially, but that finally worked itself out. They lasted quite while, but recently got to the point where they were bugging me, so I pulled the 14"/4-piston combo off the front and put the 15"/6-piston combo on in its place. When you do this swap, you also have to put a 1.125" master on it to have the correct pedal pressure.
Because I'm incapable of making anything easy, I also wanted to swap the ABS unit to one I bought off a crashed Shelby GT500CFTP. I didn't know if it was different, but my logic was that it might have a spicier ABS tuning than mine. So when I did the swap, that was the first thing I had to make work. This is the second time I've done this exercise. This time I was able to force the VIN through ForScan. Still, no luck , though. It wouldn't play nicely with the other boxes. So, I put the other original ABS controller back in, bled everything, fixed an exhaust rattle and dropped it back on the ground.
I've literally only driven around the block on it, but it feels reasonable. I'll get some time to play with it in the next week or so. Expect reports of me braking 5 feet later at the school crossing stop sign in the near future. I left the rears the same. I've still got 1/2 pad life left. Honestly, why bother?
What is the 'go to' rear stock-type 13" vented disc which has the venting on the correct side of the hat? I went to the dealership this morning, but all their book pictures have the venting on the wrong side.
