Been searching and can't find the black decal that goes across the trunk lid under the faux gas cap. Anyone have a part number or where I can get it? Thanks.
I recovered mine with Scotchprint 3M Matte Black that you can find at Amazon. Relatively easy to work with and cheap if you make a mistake. Or take off the faux cap and have any tint/ wrap vendor do it for you.
For some reason the black decal is no longer listed but you can see it called out in the image. Best bet is to call one of the large online Ford parts retailers or do as 576 suggested.
Thanks guys for the info. Very helpful. Would like the OEM one and it shows its $72. Going to see how much a wrap place will charge and go from there. Just need tondo this ASAP.
I took my faux cap off and messed up the decal in the process. Boy is that cap stuck on there!!!
Thank again and I will post results.
i just ordered and received mine from Ford.I did not get the trunk rear panel applied as i now prefer it with it off.That decal always seems to get marked so after my car was re painted,I left it off.I bought the Boss 302 insert for the gas cap and looks killer.Check out my pics page 169 i believe in "What did you do to your Boss today".I will keep the rear decal just in case i change my mind,but should be no problem getting it from Ford.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
