- 899
- 548
Would the oil filter adapter from the GT350 not work?
Just curious, are you utilizing break in oil? This project is very cool....pufferfish said:There was no time to order the GT350 adapter, but even if I had, it may require something else special if the bypass is electronically controlled or requires ancilliary items to function. This would all eat up valuable time. The plate worked perfectly anyhow! Got it all buttoned up and I don't know if its the time I've been without the car, but it feels MUCH stronger than the old engine. I performed around 20 minutes of breakin, holding a steady state of 3500rpm down the highway, with short bursts to 7000 under load. I can't exaclty follow the ring manufacturer's recommended breakin procedure, but that should sufficiently get the breakin started off right before trying to murder it on the dyno tomorrow.
I'm really excited for tomorrows results! WOOT WOOT!!
The Accufab is the whole reason I am trying to work with the GT350 TB. It made great power on the boss motor, but it had issues that caused limp mode. I know it would do well on this motor as well, but won't risk the limp mode again.Sean said:That is badass Steve!! I have heard some rumors that Eric Brooks was close to figuring something out, but those were only rumors. I know there was another guy who was working with Jim at JDM in NJ and then Shaun at AED and that sort of fizzled out as well. In the mean time have you given any thought to the Accufab 84.5mm throttle body? It should get some more airflow and the throttle response should still be pretty darn good. I know that it will outflow the FRPP 90mm, so maybe it would outflow the GT350TB as well.
5.2L voddo blockMad Hatter said:Really a great start! Could you remind us what you have on your Boss engine so far? Did you have cams already etc??
Sean said:Tim Eichhorn over at MPR Racing Engines works on quite a few GT500 engines with the PTWA liners (from what I can recall) and if you need to bounce some ideas off of him or get some interest in the ring gap specs he is always willing to help out and talk cars, engines etc. He is a super nice guy and always had excellent customer service like you did. He was one of the people I talked with about the boundary gears btw and he loathes them so I wouldn't mention that part haha. Michael at L&M is also a good resource to speak with although he is comes across sort of short over the phone, but one of the best in the business as well.
That sucks about the motor though. Having to tear it down all the way that far again is a pain the behind.
