Cobrarob said:
installed Vorshlags 18x11's...
These babies are big
AWESOME!
305 Nittos? Series 35?
Did you have to modify something on the car or the wheels & tires just boted on?
Thanks. No modifications, I already had the Roush steering limiters installed,no rubbing.
Tried to take a pic of strut/wheel space... I would say littl less than 1/4 inch.
started the seat cover change. passenger side took me about 3 hour.
I'll post more pictures after the job is done completely
Those look familiar! Nice work.
Hey Bulent,
I can see you continue to take good care of your babies! :)
Nice!
patrickshelby said:
Hey Bulent,
Nice!
Hi Patrick
Yes of course. Whats about your babies? everything ok? do you ordered a gt350? :)
You know, i still have your Blowfish Support-bracket in my cellar.
F.D. Sako said:
Awesome!
It's good to know these fit with standard shocks.
The standard shocks are the easiest to fit. The bodies are the smallest diameter and large diameter springs can have the perch moved up pretty far to clear the tire. The use of coilovers and/or 315 tires may require a 3mm spacer.
And yep, that is a super tight fit to get them as inboard as possible.
Yep they fit great! Blasted over an hour with them around me neighborhood,no probs.
Tell Jon thanks for the help
Were steering limiters a Vorshalg requirement (or advice) or did you just happen to have them on and thought they were needed?
In other words: Do you think you could have done without?
Had them on the car already. Didn't push my brake ducts towards the middle of the car so I was gettin some rubbing last year. Heard someone used them so I tried them. With the 18x11 and big 305's,there's no rubbing with my setup.Maybe if I take the limiters out,I would experience the same rub on the ducts s last year,but now they fit with no probs. Hope this helps.
Put on some Lamin-X protective headlight covers. The light blue tint is subtle but should provide some protection both on the track and on the street. It's pretty thick stuff and went on easy. Was looking for something different, something that could cover the lenses while on the track but could only find something that used double sided tape which make it difficult to remove for the street,
Before:
After:
i noticed today that the shelby clutch-fluid reservoir has a leak. unfortunately i hadn't the time to remove it from the boss and search the leak. half of the fluid is gone out.
