batman48195
I never get tired of driving it!
Are there any down sides to running Dot 4 all year round? Will cold weather affect the braking as the fluid is "thicker" I assume? Sorry if this is a dumb question.
Thanks,
Brian
Thanks,
Brian
racered302 said:How did you get it to work? I pumped it up to 10-15psi, opened the bleeder and nothing, not even a dribble.
YellowBoss said:Brian, no down sides at all and not a stupid question. The only fluid that would be bad to use is a DOT 5.1, it will not mix with water. In this case water "bubbles" in the lines and make their way to the caliper where they collect and reduce the boiling point of the fluid to the point you could boil them under street use. This fluid is used by people with expensive collector cars since it will hurt the paint if it leaks during maintenance.
batman48195 said:Thank you. Was wondering which fluid is used by the people with expensive cars, the Dot 4 or 5.1 and which one hurts the paint?
Thanks
Brian
bulldogracer said:Can you mix the old fluid with the new racing DOT4 or will this cause problems? Thanks!
