Brandon302 said:Other then what has been stated I believe it also drops the car a little.
GottaBoss said:Okay, I'm confused. If the wheel is smaller but the sidewall is taller, making the overall diameter the same, how in the heck does it drop the car?
Grant 302 said:Reasons for me are: lower wheel weights (and combined wheel/tire weights), tire size/width availability, clearance, looks.
Many people want lower sidewalls for the track...and often tire diameters are also smaller in 18" for given widths. Shorter tires will also reduce mass where it counts the most.
To be honest I was about to get some 20 inch amr wheels from american muscle. But was wondering if I should change my gears if I do to 3.55 or lower what do you think? And I'm getting 20s basiclly for looks I want to lower it a good bit to have no wheel gap.NFSBOSS said:Personally I'd keep the 19's for the street. While the 18's are lighter, which you'll be able to take advantage of on a road course, they aren't going to make a big difference on the street other than cost. With 18's your car will sit lower to the ground by 1" if you use the same profile tires and you'll have a larger wheel gap front and rear. If you're worried about handling on the street swap out the Pirelli's for some Michelin PSS tires and call it a day.
You convinced me to stay with 19s. And I was wondering if there are any benifits from switching to a lower gear. I want to pull harder in 3rd and 4th is this the right thing to doWinterSucks said:AFAIK, the traction control uses wheel speed sensors to detect if the rear is slipping based on the difference in rotational speed of the front and rear, but there is some wiggle room. Just make sure that the overall diameter is close front to back, does not have to be exact. The stock fronts are 27.2" and the rears are 26.9". I wouldn't go smaller for the street since it will cause a speedometer error and you will end up with the car registering a higher mileage than actual.
I am going to speculate that if you go to 20s you will notice the car will be slower and the tires very expensive.
You'll be fine.jfolsom28 said:To be honest I was about to get some 20 inch amr wheels from american muscle. But was wondering if I should change my gears if I do to 3.55 or lower what do you think? And I'm getting 20s basiclly for looks I want to lower it a good bit to have no wheel gap.
Do you guys think that switching to 20s in the rear will make my car noticable slower?WinterSucks said:AFAIK, the traction control uses wheel speed sensors to detect if the rear is slipping based on the difference in rotational speed of the front and rear, but there is some wiggle room. Just make sure that the overall diameter is close front to back, does not have to be exact. The stock fronts are 27.2" and the rears are 26.9". I wouldn't go smaller for the street since it will cause a speedometer error and you will end up with the car registering a higher mileage than actual.
GottaBoss said:I was under the impression that a different overall diameter/circumference tire would make the computers unhappy. Is that not the case or does it only cause a problem after a certain point?
