rcode1965 said:Those Forgestar's look great Dean. Been thinking of getting a set also, or at least it's one of my favorite's so far. Can you tell me what size of wheel and tire size you went with? Thanks.
Which wheels are you using?oldbossman said:I ran at the track for the first time this past weekend with the following setup (vs the original 19" wheels/tires):
front 18 X 9.5 275/40/18 Nitto NT05
rear 18 X 10.5 295/35/18 NT05
Tire wear at the end of the weekiend looked pretty good. My daughter was also running the same car in the green run group and we had back to back stints so I gave the brakes a good workout. I have the brake cooling ducts and there was absolutely no fade the entire weekend with outside temps on Sunday around 80F. The engine temp guage never moved from the 12 oclock position. I was running the PF 01 pads in the front and PF 97 in rear. I thought they had good stopping power.
I did find that you need to turn the traction control completely off in order to be able to accelerate out of tight turns. I really loved the way you could toss the car around using the throttle. Lots of fun.
However, on the final run of the weekend the check engine light came on so I guess something in the emissions system didn't like the abuse. Will get it checked out. Anyone else had the check engine light come on?
Did you receive yours?PeteInCT said:About 10 lbs each
I'll get that every now and again right after I shut the car off when it's really hot after running it hard, and then starting it back up.oldbossman said:However, on the final run of the weekend the check engine light came on so I guess something in the emissions system didn't like the abuse. Will get it checked out. Anyone else had the check engine light come on?
Many of us have had this happen. Mine cleared by itself after a day or two or driving.oldbossman said:However, on the final run of the weekend the check engine light came on so I guess something in the emissions system didn't like the abuse. Will get it checked out. Anyone else had the check engine light come on?
ArizonaGT said:oh snap!
Glad you liked them since I'm afraid I'll get blamed if somebody goes with these and hates themoldbossman said:I ran at the track for the first time this past weekend with the following setup (vs the original 19" wheels/tires):
Did you turn AdvanceTrac off or just go Sport Mode. With it all off, you can really toss it through the corners. It also seems to tame the ABS.oldbossman said:I did find that you need to turn the traction control completely off in order to be able to accelerate out of tight turns. I really loved the way you could toss the car around using the throttle. Lots of fun.
It's most likely a P0300, P0305 or P0306. It's pretty common from track use. The PCM perceives misfires, but they're "phantom". The cure is to have your dealer perform a cranshaft sensor relearn process. The crankshaft position sensor is getting fooled into reading misfires. Scott said Ford told him it's from hitting the rev limiter while I had another Ford person tell me it was from vibrations transmitted through the driveline from track curbing. Either way the crank sensor relearn TSB is the cure.oldbossman said:However, on the final run of the weekend the check engine light came on so I guess something in the emissions system didn't like the abuse. Will get it checked out. Anyone else had the check engine light come on?
I'm just a regular Boss and can't possibly run with the big dog LS's ;DPeteInCT said:ArizonaGT said:oh snap!
AZ - Gary knows it's really an unfair comparison since his car is not BLACK. If I ever get to drive with him I promise to not let it out of 3'rd gear ! ;D
PS: Gary, I like lamb chops too... Maybe some veal ? A nice Osso Bucco possibly... :
cloud9 said:I'm just a regular Boss and can't possibly run with the big dog LS's ;D
Now that's a rack
Uploaded with ImageShack.us
Dean#4AI said:rcode1965 said:Those Forgestar's look great Dean. Been thinking of getting a set also, or at least it's one of my favorite's so far. Can you tell me what size of wheel and tire size you went with? Thanks.
I'm running a square setup with 18x10 wheels and 275/40 Nitto NT01 tires. The tire diameter is the same as the stock 19s.
