Mild NA coyote build.
Chewed up rod bearings during oil starvation.. so decided to do a little upgrading.
Manley 11.5:1
Manley Rods
Boss crank
Oil squirter blockoffs
Billet oil pump gears
Boss valve springs
CompCams NA stage 3 w/phase limiters
ARP hardware throughout
CJ Pulse Ring
MMR head cooling mod.
Boss oil pan
Car already had Boss 302 IMF/Air raid CAI
BBK ceramic long tubes.
Should be fun, I will follow up to give driving impressions on the cams..
Sent from my DROID4 using Tapatalk
7,603
5,357
Manley 11.5:1
Manley Rods
Boss crank
Boss valve springs
CJ Pulse Ring
Boss oil pan
Interesting build
Any estimate on costs, parts, machine work etc??
Yeah parts w/gasket kit and other ancillaries ran about $6K from modularmotorracing. Clean up heads, balance assembly, install figure another $2K. Lund tuning $450. Should be good for around 500 whp all said and done. All kinds of other supporting suspension, drive train, brake upgrades.
7,603
5,357
Cool!!
Your block and heads, HD lower end and upgrades close to the HD Aiuminator engine for $9K. Add in the CJ manifold and TB and you just about have the CJ.
Good luck with your build.
Interested in your dyne numbers.
Yeah I have an 84.5MM accufab.. funny thing, I didn't get the CJ intake cuz it was too much $. LOL
steveespo said:
Get a road race oil pan so you don't have oil starvation again. Boss pan is marginally better than GT pan. Moroso pan is great, so is the Ford Racing pan, just $700 more than the Moroso.
Great advice. Moroso Alloy on the way. Looking back, seems silly that I didn't order it in the first place.
centri, did you ever overfill the pan 1/4-1/2qrt above the max line during track events?
Just curious if an oil pan is something I have to add to the list, when I start running slicks down the line..
roadhouse said:
E85?? Did you say E85? :D Looking forward to seeing the finished product!
I know I know, but then I shoulda went with 13:1 pistons :) sticking with 91 for now. Still have my 47lb injectors.. so ya never know.
1,281
Tulsa, OK
Because streetcar...You'd have to start trailering with E, then it would be a racecar. ;)
