Jeff said:hi guys. quick question can I run a 19x10 et42 in the front? with say a 275/35 or a 265/35? is brake caliper clearance the main issue here?
Jeff said:I was only thinking 265 in an effort to make it fit. If i can i'm going to try 285/35's and run square.
I'm trying to fill out my front wheel wells more. The 19x9 et35 with 255/40s look terrible.
NFSBOSS said:The biggest clearance issue up front is the strut/spring. I think most 285's clear with no issues.
Jeff said:I have forgestar CF5s now 19x9 and 19x10s. I want to replace the 19x9s with 19x10s for the fronts. I can test this by taking my existing 19x10s and putting them on the front but it's still like 20 out right now so i'm trying to put that off for warmer weather. just thinking the stock 285s are too wide so 275s?
cp85gt said:Grant 302, I would be interested in how you like the 295 30 19 Michelin pss on the 19 x 10 F14's. Are they a bit too big for a 10" wide wheel or are they a good match?
Jeff said:
