Thanks for that tip!I run the schroth 4 point harness in my s197 with schroth’s dedicated HANS device. The neck restraint is designed to route and fit the 4 point straps exactly. Be careful that whatever you get works with the width of the schroth harnesses. I think they are narrower.
And here I was getting pissy about being hit with rubber and a few stones through open windows. Always let the track crew know about any debris on track. I also push if you have the gear, wear all the gear.A photo against open face helmets. Happened back in 2010 in my S2000 passing a guy that was pulling over to the side of the track. Lots of blood and ten stitches later a lesson on why to wear a full face. I was also using a roll bar ,5 point and Hans.
