S650 Knuckle to Toe Link on 2024 GT Performance Pack
Rochester, NY
I am replacing the Lower control arm bearing on my 2024 S650 GT Performance Pack Premium. I also want to upgrade the knuckle to toe link bearing. My question: Does the Performance Pack car already come with the Ford Performance knuckle to toe link bearing or is it the standard knuckle to toe link bearing? Thanks
The s550 cars have a rubber bushing there. My guess is that they have not upgraded it on the s650, so will you just have to check by pulling a wheel. Sorry, not that helpful.
If you decide to install a bearing there, research the width of the bearing and the width of the toe link fork to be sure they are compatible. The FP bearing is the best choice because it is the narrowest, and most aftermarket toe links are designed for that.
