Guess I'm swapping in the donor cluster/clock spring/key setup next then.
This doner engine ran on the pallet.
@Stangra is right. You gotta use FORScan to sync everything together. Whichever parts did not come with the pallet need to be setup on the pallet's PCM. Before you start, make sure you have your two keys that fit the ignition and that they have unique transponders.I'm now wondering if the clock spring/cluster is somehow tied to the BCM?
I'm to the point where I put power to everything today and tried to crank the motor. No luck. I got what looked like a security lock out.
I have swapped in the motor/transmission combo, pedal assy, anti-lock module, BCM, and PCM.
The vehicle still has its original clock spring/cluster/keys.
No crank, just lights on the cluster, one of which was the "lock"symbol.
I did hook up the neutral safety/pedal assy harness to the connector above the pedal area.
Any thoughts?
Everything I'm swapping from the pallet came from the same vehicle. It was running on the pallet in my garage. I bought it from Cleveland Performance.@Stangra is right. You gotta use FORScan to sync everything together. Whichever parts did not come with the pallet need to be setup on the pallet's PCM. Before you start, make sure you have your two keys that fit the ignition and that they have unique transponders.
Here's a video that shows how to do it. In this video, the guy is doing a '13-14 cluster swap onto a '11-12 car, but the procedure will be the same. There may be more depending on what other modules you need to add.When you're done, you should check the other modules on the car against the AsBuilt configuration for the VIN of a car that matches the setup you're using. If you have the VIN of your donor, that should do it (assuming it has the same trim level). If not, I'd just go onto Copart and look for a car that matches your build, and use it's VIN to get the codes. If I understand right, your donor was a manual, so hopefully you won't need to flash the PCM right away. But if/when you need to flash it, if you don't have the VIN, you can use the VIN you grab from Copart (or somewhere like that) to program your PCM as well.
Just so you know, I don't think you need to do any of that. I think the problem you're facing currently is that you need to initialize the cluster. But if you want to skip that, it's easy enough to use the pallet's cluster (you will still need to program your keys). The clocksprings don't have any computer components that need programming. Either one of them will work.Everything I'm swapping from the pallet came from the same vehicle. It was running on the pallet in my garage. I bought it from Cleveland Performance.
I should've just swapped all the components over like I planned. I even have a complete body harness, but so far I've just done the pin swap in the ECU plug.
Im headed out of town for a week, I'll swap in the last items next weekend and give her another try.
Because the ignition lock cylinder that came with the pallet isn't in your car (unless you swapped it). The key has to fit the lock, nothing more than that. If you want to use the pallet's keys, you can swap the lock cylinders but there's no need to do that unless you prefer to do the lock cylinder swap instead of programming the keys. My understanding is that the transceiver rings have nothing unique about them so there's no need to swap those.Why would I need to program the key if the one that came with the pallet starts the pallet?
If the key, transponder, and cluster all get swapped then it should fire, right? Isn't the transponder in the clock spring?
ehhh maybe wishful thinking on my part. I saw the oil and thought I'd found something. But it's probably just spillage from oil fills. Will update after I run the breather test.I don't see a crack. Could you zoom in or direct me a bit on where I should be looking?
I've gotten some flat out wrong information a few imes while using AI to assist with my build. That being said, it's been very helpful at times too, especially when trying to stumble around in FORscan.Side note: AI is a lot less useful than I was giving it credit for. The more things I've ruled out on this car the more crazy it's ideas have become. I'm gonna stop using it as my sounding board... lately it's just been sending me down a bunch of rabbit holes.
Absolutely! I'm a history nerd and I watched a history guy that does his own research do a Youtube vid about how info can be manipulated t create "facts". I'll never trust AI for anythingI've gotten some flat out wrong information a few imes while using AI to assist with my build. That being said, it's been very helpful at times too, especially when trying to stumble around in FORscan.
I manipulated the Gemini AI search results about S650s and brake pads. Ask Google what are the OEM brake pads for the Dark Horse, and it will tell you Ferodo DS2500. They're not. The OEM pads are made by Akebono.Absolutely! I'm a history nerd and I watched a history guy that does his own research do a Youtube vid about how info can be manipulated t create "facts". I'll never trust AI for anything
I think it's the end of the road for my bug hunting for the time being at least. The only other stuff I can think of would be cylinder head things like rocker arms but I have none of the usual noise associated with that so I think I'm just gonna leave it be and do the best I can with what I have.
