‘Bouncy’ rear end after rear lower control arm monoball bearing install on a GT350R
I installed a set of FTBR monoball bearings in the rear lower control arms of my GT350R. The immediate result was a much ‘bouncier’ rear end. Suspension Is more or less stock (stock MR dampers and springs) with the FP toe link bearing and SPC camber arms. I am running the FP track alignment spec
at this point. I am questioning if those bearings are maybe too ‘tight’. I am noticing an improvement the more car is used but nowhere close to before the install. Will they ever break in to the point the car will feel similar to before? I really appreciate the feel of the rear end otherwise but I need to do something about this bounciness. Is this expected with this type of ’upgrade’? I am willing to redo it with a different brand if that will address the issue.
I would appreciate any advice on this. Thanks a lot!
I did not get any extra bounce when I made the same changes to my gt500 mag ride. (cortex arm bearings and fp toe link bearing). But I do have a DSC sport controller that has some added rebound dialed into the rear. Before the shocks and springs went in the rear suspension was very free moving.
The underdamped shocks hypothesis crossed my mind as well - especially since when switching to 'sportier' suspension modes things get better. Short of physically replacing the shocks, I guess the DSC controller could be something that might help. Speaking of which, has anyone run the Steeda one on a stock suspension?
The part that made me also think those bearings might be a 'tad' tight is when driving the car in cold weather last winter (30-40F) the bounciness was pretty extreme. As the ambient temps went up and I drove the car more, the feel has been improving. Do these things break in over time?
Have you checked to see if the rear ride height sensors are correctly installed and connected after the work was complete? If not, they might have put the VDM module into some kind of confused state and blocked the function of the magride shocks. I've never touched my rear sensors, so I'm guessing, but the problem sounds more like a disabled magride than a bushing issue. If you have Forscan you can check the height sensor operation by scanning the VDM for codes and by checking the height sensor voltages.
I'm sensitive to this because I had a similar problem on my BMW E92 M3 after I did some work on the suspension, and it turned out that I'd put the rear height sensor back in with the linkage at the wrong angle. On that car, the sensor only controlled the headlight angle but the lights were pointed steeply downward (couldn't drive it that way) because of the install error. And it was an easy mistake to make - I didn't figure it out until I compared a photo of the correct install with what I'd done and then it was obvious..
Regarding the question on VDM and height sensors. I hooked up Forscan and everything seems happy. No error codes, performed the ride height calibration with no problems. That is why I am honing in on the bushings to be honest.
FTBR told me they have not seen this before and to check the install. They also mentioned their bushings are very tight out of the box.
I might just swap them for Cortex ones or go back to my original LCAs which I kept. I am a bit torn. But what I am experiencing is more than I bargained for in the beginning.
How did you do the ride height calibration? The early GT350/GT350R's had different calibration processes. The GT350 calibration was at static ride height (car sitting on level ground) and the R was at full droop (car on a lift in the air). That may have changed in later model years.
The reason I'm bringing this up is that it really does sound like a magride problem. I installed an early DSC controller back in 2017 and it was uncalibrated and my car bounced around like crazy until I got the calibration file loaded. Your symptoms sounded familiar.
Both Forscan and the tool my indy shop uses with the same results. I calibrated initially like the early Rs (suspension full droop) and then later tried like the tool was instructing (after 2018 suspension at ride height).
An update here. I decided to bite the bullet and swap the bearings for the Cortex ones on the hypothesis that they are excessively tight. I was right. Off the car you need a considerable amount of effort to make them move. Cortex made a whole world of difference. The car is back to normal.
But...
It seems that my FP toe link bearings are now shot (M-5A460-M). They have play on the longitudinal axis (direction they are inserted in the knuckle). Both sides. Not sure if the FTBR LCA bearing had anything to do with this but now I have to solve this problem too.
Bottom line, stay away from FTBR LCA bearings. They might work for some people, clearly in my case they were a total failure and caused a lot of wasted time and money.
Also, are there more durable alternatives to the FP toe link bearings?
Thanks!
Completely back to normal :) New set of toe link bearings are in. Car drives great again. Cortex won a long term customer.
Does this add NVH ? My OEM Bushings on the rear are I guess shot based on noises over bumps but I wonder if I should go Polibushing (Steeda) or full Bearings and what kind of NVH this will add ?
Absolutely nothing in terms of NVH. They're purely a positive. They're the best cheap thing you can do, IMO.
It's an insult that PP1 doesn't have these.
The RLCA Bearings you mean ? Or the Knuckle to toe-links ones (I do have this). I wonder should I go Polybushings or full blown Bearings as my roads are full of potholes and with the Ohlins and all the Steeda IRS parts it's a ruff ride as it is.
I use a Poly bush in the RLCA position for exactly the reason you say. I have SuperPro, which may not exist any more. It has about 90% of the deflection improvement of the bearing and no noticeable NVH (but I'm deaf). It works fine, but next time I'll probably just go bearing.
Subframe bushings make a NVH difference, but it improves the handling of the car significantly.
RLCA do not really add much NVH if any, rather they carry resonance frequencies more efficiently I guess (like your tire noise becomes a bit more obvious). As long as you do not do what I did (use the FTBR ones) they are great.
When I was originally building the car, I was interested in a class that didn't allow actual bearings, so that's why I went with bushings. Later, that changed. There's something to be said for the bushing reducing the peak impact loads to the chassis. The deflection under load is significantly less than the stock piece, so I'm getting probably 90% less unwanted movement compared to the floppy stock bush. The bearing might add a tiny bit more rear security, but I bet it's not much.
I'm more worried for the drive to and from a track regarding NVH from bearings as you know potholes and crappy roads. I think this is the last part of the puzzle I have left in the rear as I already did a lot: IRS Base Kit, Diff Inserts, Toe-Links, FP knuckle bearings and the rear is much better now but still need the RLCA Bushings changed. So I'm debating ether Cortex or Steeda Poli Bushings.
