ok I understand the bigger rotor and stopping power. but is it worth upgrading from 12 to 13.8. I read caliper is the same ? I know rotors are different but are the mounts different? axle and caliper? thanks chris
I upgraded mine several years ago with a custom bracket. Same caliper and pad (Carbotech XP-8 in full time) DD with about 3 HPDE days per year. I don't notice any difference in stopping, but I imagine there is a benefit to displacing heat with the additional surface area. I did mine mainly for 'looks', since it fills up the back wheel. Worth it for that reason...but for functionality, doubt you will notice much of a difference.
pad life is longer on the larger rotor. bit more weight out back, but ultimately I feel its much easier on consumables (rotors and pads last much longer)
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
